Will 2000 CR250 wheels Fit 2002-2003 CRF450?
I have an extra set of black excell's for my 2000 cr250.
Does anyone know if they will fit a crf450 2002-2003??? :cry:
I'm almost sure that the rear wheel will fit right on. The front wheel, you will have to get the bushing for the axel shortened, it is an easy job just compare the CRF wheel and CR and measure the difference, and get it fixed on a lathe.
I am under the belief that they are not exactly the same. I have a CR250 I just acquired. I would be interested in your Excell wheels Call me if you want sell. I am local to you.
408-655-4378
The stock wheels switch no problem as long as you have the CRF axle and spacers. DO the Excel wheels use the stock axle and spacers on the 2000 CR? If so, you are in luck.
I forgot to say that it is only the left bushing that needs som adjustments, I think it is around 5 mm it needs to be shortned.
