How to make the Kawasaki fork tool.
Go to the local hardware store and purchase the following: (or dig in your junk bin)
1 pc of 1/2 pipe 10" long minimum
1 steel pipe fitting that has a 7/8" hex on the outside (a 7/8 wrench fits it and has a 3/8 pipe minimum inside diameter)could be a 3/8 by 1/2 reducing nipple
Any fitting with a hex that will screw onto the other end of the pipe.
Assemble the pieces and weld together so they won't turn. Clean thoroughly before using. The 7/8 hex end goes down in the fork to hold the inner piece from turning while you remove the bottom bolt. The hex on the other end of the pipe is for a wrench. :cry:
