My new '05 has a chunka-chunka sound....is this normal?
After break-in and getting the pilot circuit adjusted to a reasonable setting, I was able to idle the beast down to the recommended 1700 RPM. When I idle it down, it idles strong, but makes a chunka, chunka, sound, kinda like a knock - knock - knock sound!? It sounds almost like a worn crank bearing, or a bad piston slap. I know this can't be the case, 'cause its brand new. Please tell me that this noise is normal at a slow idle on these bikes... :cry:
Nooooo!!!! Do not ride w/ chunka chunka knock knock knock!!!! It should be knock knock chunka chunk.
Thanks guys. I figured that the noise was normal, I just wanted to be sure. I know this sound is not the valves. But, I will be checking them out of curiosity this weekend anyway. :cry:
Jimbo45
That sound is very normal. Some people will try to scare you with the valve talk. Just check them now and then.
I have had a CRF450R every year since 2002 (I now have an 2005)and have run the &*%# out of them and never had a valve problem. I do maintain them very well.
They do make a lot of noise at idle.
Great Bike! Enjoy it!
TB
My engine makes noise???!!!!???
...with my exhaust I can't tell... :cry:
I would check your EXHAUST BEARINGS!! :cry: :cry: :cry:
When I crack mine open , it sounds like a giant coffee pot percolating.
therapture, you have a custom pipe. We know. EVERYBODY KNOWS. Dig?
Is it THAT loud? :cry: :cry:
