Changing speedo cable.
I know it's a simple one but I thought I'd just ask before I did it the hard way. I just want to replace my speedo cable that was chewed on my last ride. Can someone tell me the quickest easiest way.
thanks
Besty
The cable is held into the speedo drive on the wheel with one screw. Remove that screw and you should be able to remove the cable. Up top, the cable screws into the back of the speedo kinda like a CB antenna - unscrew that and you should be good to go. The cable itself is square shaped so if it doesn't go in easily, jiggle it around a little and it should slide right in.
Hope that helps.
Thanks for that! Only thing is when I undo that screw down on the front hub the cable won't just come right out. Seems to run into the forks before it comes all the way out. Maybe I just have to get a bit more psyical with it!
I'll try again tomorrow!
