Crankcase breather box removal on '04 "S"
What is the best way to remove the black breather box on a "S" model to get at the cam chain adjuster? Or do you need to get the box out of the way to get at the adjuster in order to release the cam chain tension for cam removal? I have not started the valve check yet but just in case a valve is out of spec I want to know what I am getting into ahead of time. I have had the box loose before so I could twist the carb around to do some jetting work but I could not remove the box at that point it just would not come out.
What's the trick?
Thanks,
Roy
