How to remove stiker goo
I made the mistake of using Velcro (industrial strength) on the frame. Now, my boots have made a mess. Is there something that will remove sticker goo?
Also, the plastic parts my boots is leaving some plastic goo on my 2stroke pipe, how do I remove it?
Bug and tar remover. Any auto parts store should have it.
It depends what the glue base it, but I find that mentholated spirit works well. Sometime petrol works well. if you get desperate use paint striper! That will get anything off.
Goo Gone works really well and doesn't seem as harsh as some of the other stuff (it's citrus based I believe), I use it on my plastic all the time.
I like to use goo gone. Works great! As far as the plastic on the pipe from the boots i liked to use scotch brite and scrub it off. long as your pipe doesnt have a finish that will scratch off with the scrubbing.
Goo Gone of Goof Off. Either one, they both work excellent!
Except the paint on the clutch cover 😢
When I made the mistake of polishing my clutch cover I tried three different paint strippers. Nothing touched that crap. Its tough stuff what ever it is...
NO!!!! Do not use that it will stain your frame. If you're going to take it off a little trick is to use car wax. Works great. Or Goo Gone.
Okay...I just came from Home Depot and got the Goo Gone....
doesn't work...
I'll try Goop Off and Oops next..
Brake cleaner usually works on everything. It's even better than gasoline. It'll take sticker goop off with no problem.
doesn't work...
Goof Off is stronger than Goo Gone. The Goo Gone is better on plastic and more delicate stuff. Goof Off is what you need. Since this is on the frame, did you try carb cleaner or brake cleaner that you may already have?
😢 Nothing gets that stuff off. 😢 except your boots!
