install FMF Q now pops and backfires need help
hi have new 03crf450 ran fine with stock pipe install FMF Q now hard to start,pops and backfires flames when giving it gas. Is it to lean ? jetting recomendations?
thanks
casey
Make sure you do not have exhaust leaks. Did you replace the gasket in the head? If all is good, I would try a quarter turn of the fuel screw(out)to see if it improves. If it does you are lean.
