HELP HELP!!!!!
I just bought a 2005 CRF250. When I got it home I started it and there is a rattling noise that was coming from the airbox. I took the seat off and then the air filter and the noise is still there. It sounds like it could be the slide ratteling in the carb :cry:
Is this a normal sound or should I take it back?
PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Ya it's normal from what i have been told.
Rev the piss outa it till it stops :cry:
just kidding of course
:cry:
Is the sound constant or when you let off the throttle? If its when you let off the throttle it's normal. With the bike off blip the throttle and listen for it when the slide closes. If it's making the same sound it's normal.
THANKS GUYS!!! It is only right off idle and after doing a search it seems like it is a carb slide rattle. I panicked a little but after shelling out my hard earned $$ I want to be able to ride it.
