Need to replace Chain/Sprockets with stock gearing for DRZS
Just took a quick look on the TTStore and see all their stuff is for 14/47 gearing. I ride flat terrain and 15/44 is what I like. Anybody doing 15/44 sprockets besides ordering from Suzuki. I want steel front and back. Also a 112 O-Ring chain. Gonna page through DennisKirk and RockyMountain but just thought I'd ask here incase someone knows a particular brand with 15/44 available. Thanks.
www.rockymountainmc.com should have them, try calling TT during biz
hours first, they should be able to get you the 15 & 44.
I recently got a second set of rims for street and use 14/41, very
close to 15/44, and 14/47 for my dirt set. Lower number rears are
hard to find in steel and I had to get my 41 in aluminum from
www.sprocketspecialists.com 44 should be easier to find.
Bikezone.com I believe is where I got mine. They had an excellent guide that went through the available brands and teeth specifically for your bike.
I ordered a susnstar steel rear, pretty much the same as stock. When I took it off at 15000 miles, I was able to match the old rear with the new, no wear, couldn't believe it.
Now as to the front , significant wear, but I went with OEM sprocket, and that was slightly costly, but that's what I wanted and with the CSprocket problem some have gotten sprockets with thickness differences.
I did pay around $39 for the 44tooth steel
BTW, the sprocket nuts are made from real butter, the softest I've ever seen. I stripped 3 of them with a 12 point box end, highly reccomend getting a 6 point box end before tackling.
I have a stock 44 tooth from my S, 50 miles on it street break in time, clean and no rust. $25 shipped if you want it.
Frank
Thanks...Would have bought it from ya but bought chain and sprockets about an hour or so after my post. 15T Moose and 44T JT Sprockets
