XR50 Crank
You can't beat that deal from Beatrice Cycle. I purchased the exact same one from them, for $84.99, and it works like a charm. It already has the crank bearings installed, along with the cam chain drive gear. All you have to do is remove the old crank assembly, and install the new one.
Thanks.
Also how hard was it to remove the crank (split the cases)
Anything I need to be aware of?
The best guide for all of your maintenance needs can be found Here
The Clymer Manual gives you detailed, step-by-step instructions from start to finish for a complete disassembly and re-assembly.
