Balancing Bike
I own an 04 cr 450. How do you go about measuring to see if your bike is balanced? To see if your front end and back end is equal? Thanks
well hopefully the bike is all stock suspension to start with,(nobodys put any different valves or springs in it ) and you should read how to set the race sag section in the manuel for the rear,--dont worry about the ft at this time----and the manuel will also tell you where to have the clickers set at stock and learn where they are and then ride the bike and see how it feels for you --------you want about 100 mm of sag in the rear with you on the bike messured from when its on the stand and then with you on it on the ground-----------this is a starting point -----the manuels are real good and packed full of info to start with----if you dont have one get one !!
