03-250f shock compression shim stack (stock)
Does anyone have the stock compression shim stack for the rear shock (03 250F)? I had the shock revalved for woods and now would like to get it back to an MX setting..If not stock,,, anyone willing to share a tried&true stack for MX? Thanks.
Stock info for the '04 CRF250F can be found here. Don't know if this is the same as an '03, but it should be close.
I assume you mean the YZ250F as there no other 03 250Fs.
Here you go-
03 YZ250F Stock stack
Nut
Washer
23x.2
24x.3
26x.3
28x.3
30x.3
32x.3
34x.3
36x.3
28x.1
36x.2-6
Piston
40x.2-11 (yes, 11)
34x.1
30x.1
40x.1
38x.25
36x.25
34x.25
32x.25
30x.25
28x.2
24x.2
22x.2
Hope this helps.
Bz Joe 😢
