wats the ill effect of too little fork oil?
hi guys,
i wonder wat the ill effect of too little fork oil does for a trail riding xr250r?
i change the fork oil today& out came 400cc per fork, i put back in 535cc as per manual,
btw i weight 123lbs& i believe everything is stock on the bike,
well on that bike probably not much-------it may suck air when your almost extended and loose rebound damping maybe but doubtfull ,------you may have ben able to bottem it easier ---but at 123 lbs and trail riding i kinda dought that to -------so its good you know now that it is correct and you can start stock and go from there.
