Supertrapp ISDE2
Hello All,
Does any one have any experience with the above slip-on. Will it fit on an "S"? How quiet is the quiet core? Noticable HP gains?
I was looking at the dyno chart that Burned posted from the Yosh site, on the "S" it only bumps up the ponys 1 HP peak, actually less HP peak with the full tec insert. Early on it does produce more ponies tho'. Just rambling.
Thanks
JL
Sorry about the typos, I'm typing one handed with a baby on my lap.
Thanks for the reply. I guess the point to my ramble was to question if it is worth for one pony. The graph does show the better throttle response w/the mid-range HP gains.
Now if you look at the graph for the "E" 3 ponies peak and an increase across the board, That is significant. Would I see that kind of gain with the FCR carb, "S" ignition, Low Compression, and Yosh full "E" System.
JL
yes.that graph is for a yosh pipe bolted on a bone stock S.
putting a pipe on motor that has a cork on the intake side doesnt yeild as good of gains.
the fcr along with 3x3 will allow for more gain.still wont be a E with out the cams,compression and the cdi.
