JD I'm going to JV need advice
looking for jetting recomendations for 75 deg. @ 2600ft with your jet kit. see bike and mods in sig. thanks, Phil
The same settings as sea level should be good with adjustment of the idle mixture screw inwards. If there is any sign of richness, adjust the needle clip position leaner by 1 step.
James
I'm at 6000ft. What is sea level jetting??? I'm at 172MJ, 40PJ, red 5th clip, 1 1/4 turns.
Thnaks, Phil
The standard instructions that came with your kit are for sea level. A bigger main jet than you're using now.
James
