Time to dial in suspension
Hey all..
Just looking for tips from you pro mechanics..
About how long does it typically take you to dial in your suspension? And after you set the race sag, do you leave the clickers at the lowest or highest settings and then back off or add little by little??
I finally got my suspension dialed in yesterday but it's taken three solid months of once or twice a week riding..
I wasn't having luck with the sag thing because it seemed like the rear spring kept loosening up so I kept adding preload to it untill it felt right and then little by little gave a 1/2 click to whatever adjustment I thought would help.. Each time I reset the preload I'd back out the compression and rebound to the lowest setting..
Am I on the right track?
I'm a novice MXer if it helps..
TIA
