A-Loop Kit Fuel Tube
Got an A-Loop kit off E-bay a while ago and finally got around to putting it on. It did not come with install instructions. Where does that fuel tube on the right side with the petcock connect to? I am pretty sure it is not a drain. Almost seems as if there should be a "Y" off the fuel filter tubes. I know a bunch of you guys have this A-Loop kit....any info appreciated. 😢
There are two petcocks used on the Aloop kit. You must use the petcock out of your original tank and use the petcock supplied with your kit. There should have been a "Y" connector with your purchase, if not, you got to go find one (car-part place). Run the two petcocks into the "Y" fitting, connect the "Y" fitting into the carb. You might need extra fuel line as well.
Thanks, bro. Any does the "Y" come before the filter? And does it have 2 hard tree type inlets and 1 outlet? I think this is what I am imagining I need. I will try to find one somehow 😢. Thanks for the reply 😢
