KLX125L BBR exhaust
I just mounted up the BBR exhaust system to my 2003 KLX125L.
It fit but it doesn't clear the engine case by much and I have concerns about burning the throttle cable. I also see that the kick starter is in direct contact with the pipe.
Anybody out there using the BBR exhaust? If so, did you experience the same thing?
I do.. I had to drill a new mounting hole in the frame tab, but I have no issues with the kick starter and throttle cable. Without seeing it, I suggest starting over. Mount the head pipe first (without the silencer attached), making sure it's seated against the port in the head. Since this is where your issue is, tighten it up, and check the fitment again. This all is assuming that BBR sent you the right exhaust. If you want, you can e-mail me a picture and I can compare it to mine
fastkevin@adelphia.net
I have heard of two things:
1) BBR send the wrong stuff on occasion..........
2) The BBR kit can be tight if just not right.(.....cool....)
Kevin, have you ever heard of BBR sending the wrong stuff?
Ya, they sent me wong parts clearly marked, wrong parts in the right packages, and parts missing sub-parts 😢
