XR100/ATC200X Carb Conversion ?
Does anyone know if the part numbers for the Top of the carb for the ATC200X, and the XR200 are the same. I did the conversion on my XR100(120), but had to cut the top of the carb to get the stock XR100 cable to fit. It works, but has no way to retain the cable. Thanks.
I don't think so. The atc is 24mm and the XR is 26mm. You might be able to find a piece that screws into the carb that will hold it. For a long time, I just used saftey wire to hold it. It worked fine, but was kind of ghetto, so eventually I found a top that had one of those cable holder things.
The ATC200x and XR200 do share the same top one has an adjuster and the other doesn't (at least the one's that I have, Not sure which is which). The ATC 200x is 24mm and the XR is 26mm but the top is the same.
Use a CR80 throttle cable when you get the new top.
Ok, I couldn't remember. I mix and match so much of my stuff, I can't remember which is which. Plus I'm getting old. :cry:
