05 Counter Shaft Sprocket
I am going to buy some parts for my 05 today and was just curious if you have to shim the counter shaft sprocket when you put an o-ring chain on it? I had to shim my 02.
first day i got my 05 crf i put a DID gold series x ring chain on it. I just put it on adjusted it and went ..its fine.
I rode mine for about an hour before we put hte cahin on though and i noticed that the white thing in front of the rear wheel and some of the knobbies were getting hit by the stock chain..
The countershaft sprocket spacer is only like a dollar and that's pretty cheap insurance against chewing up your case half.
I recommend Fastway
Jas
I'm using a DID o-ring on my '05 with no shim or problems.
Have you looked behind the front sprocket?
Just as good as I could see with a shop light. I used the same chain on the 04 though with no problems 😢.
I am going to answer my own question. I took my 05 for its break in Sunday 1.2hrs, went to the car wash cleaned it up got home lubed the chain,and noticed. THE CHAIN HITS THE CASE 😢 I will go get a spacer Tuesday.
