xr100 jetting
hi there.
hoping you might be able to give a little advice.
i have an xr100 that seems to be running a little
rich at 1/2 to full
throttle. the plug seems to be carbon fouled. i live
at 6200' in north lake
tahoe. the temp is 60-80 degrees. the main jet
currently is a #90 and the
clip is one from the top. the slow jet is a #38 and
the needle, the needle
jet and the pilot jet are stock. the motor and
exhaust is stock. the stock
air box and snorkel is gone, in it's place is an uni
air filter. any ideas
or suggestions on the jetting. thanks for any input.
Wow, it seems pretty lean now. Maybe , drop the needle once more and maybe go smaller than 90 on the main. Rub your finger in the back of the pipe and see if it's rich there. You can also drill you airbox for more air.
6200' is pretty high. I suspect you need lean jetting.
Did it run okay at 6200' before, or did you just recently bring it up that high?
Make sure your airfilter is not clogged.
