Valves are acting up again..very weird
Well, after bringing my bike to get the valves adjusted i rode it twice. I went to check the valves again and again my intakes were PERFECT at .005 and my exhausts were a semi-tight .010. which is fine. For some reason its harder to slide in the feelger gauge into the exhausts then it is in the intakes. The gauge on the intakes at .005 goes in snugly, while on the exhasuts its a little tougher you have to angle it right to slide it in. I think im goign to ride this weekend and check it again and if theres any change im going to re-shim them. It's weird becuase everyones having problems with their intakes it seems and im having the exact oppoiste problem
My exhaust valves are tightening up too. I checked last week and my intakes were w/in spec. and exhausts are about .005 each. I guess I get to learn how to re-shim.
