Suspension modification to Flattrack?
Hi! do you know how the CRF suspension is modified (especially the forks) when it is lowered to be used in Frattrack? Does it need any mods on the shims, springs and valves, because the speed is much higher and there isn't much jumps, etc issues?
Spacers are installed to limit travel and lower the bike. You'll probably also want to change your valving to run higher compression and rebound. Stiffer springs would probably be in order as well.
The problem with running the bike tall is that when you hit a bump while sliding sideways, the suspension wants to compress, dig in, and lauch you over the high side.
