help stuck hot start
Ok here we go hot start plunger is stuck on a customers bike. I knew it would happen sooner or later. I remember someone had a spray that disolved the corrosion. what was it?I looked and did search but nothing thanks for help
I do not know if this is the product, but I use a product called JASCO to remove rust. It works really good 😢
got it!!! used heat, penetraiting oil. tabs still broke off. I knew they would,got a thick flat tipped prybar used it as a screw driver . got it to turn freely both ways then drilled small hole and ran a screw into it and pulled.. thank goodness it came out..
[quote
Oh, Yeah that stuff is definatley the SHIZNIT. Use it on everything stuck, rusted bolts and screws, elbows and knees on Monday mornings.
Shane
