Overall maintenance?
Today I will become the proud owner or a 04 CRF 450. I ride motocross and have run 2 strokes in the past and am new to these Thumpers, but after riding one I think I'm hooked. I hope the manuals provide good instructions on maintenance but I would also like to get some feedback on what your experiences are with the maintenance routines on the various systems. How routinely do you (or do you have someone else do it) maintain things like (I know some of these are not 2 or 4 stroke specific):
Air filter
Engine oil
Transmission oil
Oil filter (also, where is the best place to get these?)
Clutch
Head and valves
Exhaust system
Carbuerator
Coolant
Forks
Shock
Cables
Brake pads (should be obvious?)
Wheels (bearings, spokes, ???)
Chain
Sprockets
Others?
Thanks for your reply!!!!!! 😢
Jim
Air filter after every trip out or sooner if conditions are real dusty.
Engine oil-every 4 hours
Transmission oil- every 4 hours
Oil filter (also, where is the best place to get these?)Scotts SS oil filter, clean every other ride.
Clutch as nec.
Head and valves- valves as nec.
Exhaust system- repack every 20 hours
Carbuerator-keep hot start clean and unsticky
Coolant-3 times a season(9 month season)
Forks-same as 2 smoke
Shock-same as 2 smoke...get sag set
Chain-keep it clean and lubed...change with sprockets
Sprockets- change when bad.
