James, Help on an 04 CRF450
I am at 4500FT, at about 40-60 degrees with your blue needle at #3 clip postition (Counting from top down), and 175 MJ. The problem i'm having is, well what you could call a hesitation at idle like a sputter or bog without twisting the throttle with it sometimes dying. After idle it runs great.
P.S
I really like your kit, I had the same idea about the different tapper too, and then I saw your kit, good idea I think. Anyway Thanks for your help! 😢
__________.:2004 CRF450:.__________
<ul type="square">[*]Fastway Accesories....Cable Clip, Case Saver, Clutch Bracket, F3 Footpegs, and Axle Blocks.
[*]Works Connection Skid Plate, Engine Gaurds, Frame Gaurds, Brake Caliper Gaurd, Rad Braces, and Anodized Goodies.
[*]Trick MX Parts ~ Anodized Goodies.
[*]Factory Connection - 1.76Kg Pressure Springs, and Oil Lock Collars.
[*]ASV Rotator Clamp
[*]Renthal--> "MC Bend" Fat Bars, and 49T Rear Sprocket
[*].:MX Bonz:. 1 1\8" Bar Clamps, and Sure-Lok Rim Lock Hardware
[*]LightSpeed Carbon Fiber Fork Wraps
[*]Tach/Hour Meter
[*]Polished Side Cases
[*]Racetemp Engine Thermometers
[*]Nology Hot-Wire
[*]SRC - 1.6kg/cm2 Rad Cap
[*]SDG Complete, High Foam Seat
[*]Fuel Line Mod
[*]Zip-Ty Fuel Mixture Screw
[*]Factory R&D P-38 Lighting
[*]AirBox Mod
[*]Back-Fire Screen Mod
[*]Storm Link
[*]Twin-Air Air Filter
[*]D.I.D ERT Gold Chain
[*]13-49 Gearing
Don't Hesitate Accelerate!!!! 😢
____________________________________
Try switching over to the red marked needle in the 5th from top clip position. Adjust the fuel screw for best idle, ~1 1/4 turns out.
James
I'll give that a try, Thanks! 😢
I did however have another question regaurding your instructions. Ok, in the instructions it says from 3000ft - 6000ft use the 175 MJ, and the Red #4, with that said then if I was going to run the richer needle (Blue) to richen the lower end, would I have to use the 180 MJ, or stick with the 175 MJ? Just wondering if you could clear that up for me, because I know the needle jet and the main jet affect each other. Thanks Again!
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]JD Jetting Kit
[*]AirBox Mod
[*]Storm Link
[*]13-49 Gearing
The needle clip position makes very little change at full throttle, but a significant change near 1/4 throttle. The result is that the main jet is not going to need to be adjusted to offset the needle clip at anything less than about 3 clip positions.
James
Ok, clip position doesn't make a dramatic differance, but what about the differance between your two Jet Needles (Blue and Red)? I figure I would only have to change between the 175 - 178 MJ for the most extreme condition changes (Cold to Hot or Hot to Cold) since I'm always riding at about the same altitude (4500ft) what do you think? 😢
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]JD Jetting Kit
[*]AirBox Mod
[*]Storm Link
[*]13-49 Gearing
The needle difference at full throttle is only slight. I would not expect the full throttle jetting to be noticeably changed by switching red/blue within 2 clip positions.
James
Ok, Thanks! 😢
[*]Tach/Hour Meter
[*]Nology Hot-Wire
[*]Fuel Line Mod
[*]AirBox Mod
[*]Storm Link
[*]13-49 Gearing
