2002 TE 570-Bogs when twisting the throttle??
My bro has a 02 TE 570 and it bogs and will stall when you gun the throttle...Any thoughts on what is causing this?
I told him he may want to clean out the carb...Is there a fuel/air mixture screw on this babdboy??
If your in Orange Co. I'd assume that you are riding in the high desert or Ocotillo Wells area. If so check the jets. The bike is jetted too lean from the factory.
I run a 40 and a 180 and 178 based on the area I ride.
Also it's geared too high unless he has changed the 14x48 if you do anything other than the flat lands of Ocotillo Wells. I run a 13x50 for tracks, Big Bear and such and run a 14x50 for all of the District37 races, at least when I use to race.
It's a good bike for our open areas once set-up.
I've got mine up for sale at $3950.00 with Dick's Racing suspension, etc.
Check it out at cycletrader.com search 2002 2002 husqvarna TE570 area code 760 if you too wish to join the Husky force.
Good luck setting your buds bike up and lit it rip - - it will for sure.
