Braking Wave 320 rotor...pads?
What brakepads works best with a Braking Wave 320mm rotor?
Brand/type?
btw: the caliper is a Brembo racing(billet,4 tit. pistons).
On a XR650 :cry:
Anyone? :cry:
For Brembo GP caliper (I'm running the same) I'd stick with Brembo sintered pads (not cheap) Another alternative is Galfer HH pads, very good as well. Make sure you run good brake fluid. :cry:
What MC are you running with the Brembo caliper(+ Brembo sint. pads): 13/14/16 mm? Is this with a (stainless steel)Braking rotor?
16x18mm Radial (I have an extra one if you want it) That's pretty much the only size that will work properly. I'm running Kevlar line, but I'm planning to switch to stainless because Kevlar gives you mushy feel. :cry:
