More CC`s
search for Millenium Technologies. They're who you want for big bore with the drz. 436cc. [cheapest]
Or look into the yosh 450 kit for the whole shebang, they'll even assemble it for ya. 😢
Millinium has three different kits. One is a 94cc bore that people call the 436, there is the 94.5cc that is a bore/aluminum sleeve called the 439, and a new 95cc bore/sleeve that is called the 450. Most the of time people actually call both the 94 and 94.5 kits 440. The reason you want to go with them is that they use an aluminum liner vs. cast iron and they also coat with a surface like comes from the factory. It is where mine is coming from and will be here tomorrow.
There is also a 450 yosh that uses a smaller bore but a 5mm offset crank.
Then you can get a falcon crank and MT cylinder and end up with a 502 😢
