Replacing Shock Piston/Valve "Ring"
WR400 Kayaba Shock
How is this done? I cut the old one out, but just can't get the new "ring" to slip over and into the piston/valve groove.
You should be able to put it on with your fingers. Warm it a bit with a hair dryer then dip it in shock fluid. Start it in the groove and while holding it there use your thumb and push & work it on the piston....like you would a piston ring. Make sure to use a new expander oring behind it.
doc
