dr. d's owners
Just got my dubach system,and after pulling it out of the box I noticed there is no clamp where the canister pipe and head pipe connect.They look thick so I don't think a clamp would even compress them tight.Has anyone had a exhaust leak at this spot, do they marry up tight for a good seal or am I missing something altogether?Thanks Rick
Almost all aftermarket pipes are this way. You could run some high temp sealant in there if your worried about it. I don't.
It works fine without it. I was a little hesitant at first also but its a really tight fit. Infact I was having issues taking it off when I tried to remove it cause I had to take off my subframe.
