01 WR 426 1/2 THROTTLE CUTOUT
I have a 01 WR426 w/ WB full exhaust and a UNI filter, YZ cam timing, and all the free mods. I just added the JD kit and installed the jets as recommended: 170m, Blue needle 3rd clip. I can't seem to clean out the middle. At almost exaclty 1/2 throttle the motor starts to sputtter and almost seem as though it's touching a rev limiter and cutting the spark (I know it's not that). Do I need to fatten it up for the exhaust? should I keep playing w/ the needle, main, pilot circuit? Please help.
Does it rev clean with the 170 at full throttle? If it does not, the main is too small and needs to be bumped up, thats where i would start. If the main is O.K, i would richen up the needle a notch at a time. It definately sounds lean to me.
Because this is a 426, the main jet will usually need to be smaller, not bigger.
Try a #168 or #165 main jet for a quick comparison. They are included in your jet kit.
James
