help with jetting 01 WR250F
I have a 01 WR250F with the exhaust baffle removed, the gray wire cut, the throttle stop cut,the air box lid removed, a 03 YZF cam installed with YZF timing and I live in California with an elevation of 0-2000ft. this being my first bike I know little about jetting a am wondering if anyone out there can help? punksucks846@yahoo.com
Please read the manual carefully for an explanation of each carburetor component.
Try adjusting the idle mixture first to see if you can get an improved idle and then check the other settings to be sure they are still stock.
James
I just bought my 01 wr250f, did almost the same mods. I ran stock 02 yzf250 jetting, difference in mods was blue wire, air cut valve, stock yzf exhaust. read my post under 2001 wr250f jetting/mods.
Good luck, Joe Ramona ca.
