05 rmz settings
mynew toy should be here next week. what recomendations do u have for my conditions?:
500-2000ft
5-15'c
track and hare scrambles
need to put a 42 pilot in and adjust the fuel screw out 2 turns.from all the way in,then go out
Stock jetting will work with the suggested changes, if you want a minimum change.
The jetting kit adds torque over the stock jetting and compensates for the lean bottom-end with the needle diameter and fuel screw rather than needing a bigger pilot jet. It also improves the top-end revs.
James
i've got the bike now and i'm about to make some changes:
remove backfire screen
dremel exhaust ports
will i need to adjust the jetting for this?
Increase the main jet 1 step with the backfire screen removed, and the same suggestions as before from above.
I have your jetting kit and would like your confirmation on the jetting I'm going to use.
The backfire screen is removed, I'll be riding in 65-85 temps, 50-90% humidity at sea level and a little above.
My plan for jetting with your kit is:
Fuel screw turned out to 2.5 (it's a Zip-Ty)
Pilot 42
Red needle 5th clip
Main 178
How's this sound?
Thanks, Joe
James will the JD kit out my 04 CRF450 work the the 05 RMZ 250, I would like try it before buying another kit.
Joe,
Your described jetting looks good.
KMM181rmz ---5c-15c is about 40-60F (32F +1.8x5c = 41F, 32F +1.8x15c = 59F)
motolink ---Try CRF450 red marked needle in the 5th from top clip position. Not all kit needles are the same, but this should be close.
James
