Ohlins rear?
Will this fit the DRZ? :cry: :cry: :cry: :cry: :cry:
delicious shock
it says it is for non linkage applications,
That would rule out the DRZ.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
