FCR and Fuel Mileage
What kind of fuel mileage can I expect from a FCR? With the minkuni I get 47 mpg. I want to upgrade to the FCR, but if the mileage will drop below 40, I don't think I'll do it.
I get only about 33 mpg, FCR, HotCam IN, Yosh. This is in the dirt right around the rev limiter most of the time though, If I actually checked on the street Im sure it would be better. I think it mainly depends on how and where your riding. Just my $0.02.
I've been getting about 80 miles easy on a S model tank. I'm still running it on prime, so I don't try to see how far it lasts. So for me.. 80+ a tank :cry:
I have a 01 E Stock exhaust.
Just PM'd Eddie and asked how to jet my FCR for 5000ft and up
142 main 5th groove snorkel out. The rest stock
I just checked my valves and found my FCR carb set up was as prescribed. I just got back from a 100 miles ride 60 dirt road and twistie mountain highway. 40 jeep trails.
I ran the snot out of her and made it home without going on reserve
I do have the Taffy mod. I won't explain that except to say I have the accelerator pump restricted to barely squirt.
I had the snorkle in for quiet a while and was consistantly seeing over 60mpg.
15/49 gearing.
hope that helps you
I changed my bike from Mikuni to FCR and the fuel mileage did change slightly but it wasn't that huge of a difference. I still get approx 45 - 50 commuting to work.
But its all about how you ride it. If your floorin it to the rev limiter all day ya its gonna suck it down quite a bit faster. But cruisin on the freeway it does just as good as the Mikuni pretty much.
Trust me you wont regret the change. :cry: :cry:
I went from around 140 miles per tank to around 130.
  • Similar Content
    • By Markl5557
      So I am going to put in an in-line fuel filter just for added protection from stuff in my gas .... and I have always used bronze element cone ones you no what I’m talking about the ones everyone seems to use but upon reading online supposedly that bronze element breaks down and doesn’t catch everything .... I have came across a moose fuel filter that has a fine nylon mesh just like what’s on the petcock filter ... any opinions on which is better ? Bronze element or mesh ?
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
