crf250x Bogging problem, brand new bike.
Any help appreciated in advance. BRAND NEW crf250x. This bike off idle will bog if you hit the throttle in neutral.
So, off low rpms, wont repsond well, will off higher rmps.
Why is this? HOW DO I GET THE BIKE NOT TO BOG FROM ZERO THROTTLE PLEASE???????????????
Thanks,
Jim
I had the same problem, terrible bog at low speeds and RPM's. I do not know a lot about jetting, but based on what I had read here I bought the JD jetting kit. I followed the instructions and lost the bog. Even though it cost a little the kit sure helped my bike. Good luck with it.
Make sure the bike is fully hot before testing the jetting. A cold bike will bog. Set the fuel screw to be slightly richer than stock and keep the idle speed up.
James
