Best dealerships to buy from,midwest
I live in chicago and I'm getting ready to buy a DRZ400S.I'm interested to know which suzuki dealership is best in the area/midwest, in terms of quality service, competent mechanics,ect...
me 2. try chicago cycle center. Champion cycle.
Both of those places suck !! I've had bad experiences with both...
Buying a bike and maintaining a bike are mutually exclusive-- sometimes it's better to buy from one place and have it serviced at another....Ill get back to you with some recommendations...
Try Prosource Motorsports.... they are outside of Chicago. I live in Arizona and bought my bike from them. Great people to deal with and great prices. :cry: There website is
Please do! I figured An urban chicago bike shop wasn't going to be the place.
Thanks! I'll check them out.
  • Similar Content
    • By BikeChimp
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
