What if?
You will need higher Octane gas. Most things that modify compression and add horsepower require you to run high octane gas.
what if......
what if your grandma had balls would she be your grandpa :cry: :cry:????
dont take it serious im just busting your balls :cry: :cry: :cry:
The porting and pipe have no reason for you changing gas but the hi-comp piston may require a higher octane gas or higher oxygenated gas like VP ultimate4 to prevent knocking.
ok thanks. but has anyone ran a hi comp piston and know for sure or not if you have to run a higher octane gas?
I put the 262 kits on ours which kicks the compression up +1.5, they have to run with premium gas.
I dont know if the +.75 piston needs premium though.
The best we have is 93. could add some octane booster.?
Would octane booster make the bike run better stock?
