oil leak
I have an oil leak, left front of engine. Must be from a rock hit. It only leaks when running or right after a ride. I have tried JB weld to close the seeping leak, but no luck. Any other suggestions? It is not far from the left side cover. I was thinking of removing it to see if I could see the damage from inside the case? What is behind that left side cover? Anything fancy to put back together? Will I have some access to the front of the case? thanks
