ttr-225 CCT help!!!
Hello guys, I have a 01 ttr-225 that started to make a chunking sound from the Cam chain tensioner. I figured I would take it out and see if the spring is broke (automatic if you could tell). I took it apart and it seems to be fine. I tried to search around the web but I can not find anything like this one. This one is hard to explain, the spings appears that it needs to be wound up and as it tried to de-wind, it turns a screw looking thing put pressure on the chain guide.
Now the main question is... Do I have to wind the spring before I reinstall it? Any pointers will help!
I have tried to locate a Chlymers service manual locally but I guess no one has it. I refuse to spend 85.00 on a factory manual. Either way, I would still have order it
anyone?
