Broken choke flap
The Choke flap on my xr400 broke a few weeks and ago, which eventually led me to this forum. After searching and reading old posts it seems some people don't think this can happen even when warned, or think its the screws that come off. For me the bottom of the choke plate broke off after the flap beat it off and that approx. 3/8x1-1/2" piece made its way into the combustion chamber and luckily only closed the gap on the plug, since I didn't know about the choke flap problem at the time I thought the timing chain must have slipped and was quite surprised when I found that piece of the choke flap sitting on the piston and had to try and figure out where it came from. I am still amazed that big piece managed to get through one of the intake valves and into the combustion chamber with no damage to the engine, not even a bent valve! There was a warning about 5 minutes before that happened and that was that the throttle got stuck at about 1/4 throttle for a second. This is a '99 my brother got in '02 so it does have a bit of time on it, but if you haven't yet, at least silicone/rtv your choke plate or get an aftermarket one.
I have pictures if anyone wants to host them or see them.
Yea ok lets see the photo's.
This is old news, the old "broken choke butterfly" was a reasonably common on high milage XR600's and has happened on the odd XR4. It happened to one of my XR6's and unfortunately did a little more damage than a closed up plug gap, it put a deep score in the cylinder that rendered it useless as it was the nickelsil coated cylinder model (1988-90). As a precaution ever since, I've been removing these choke plates and replacing them with an aftermarket type bought from Ballards Xr's only in OZ, these have no flap which eliminates any weak point from the plate!
Old yes, but very important news!
I bought my bike used and the first thing I did was to replace the flap with one from XR's Only. Man am I glad I did as the stock flap was cracked almost halfway through.
Cheap and easy to install and will save you some big money if it were to fail.
I know its old news, but I wanted to make sure everyone knew that it can and will happen if you don't do something about it. I would post the pics but I don't have anywhere to host them.
I was going to e-mail you the pics but this forum doesn't seem to have the e-mail through the forum feature....or at least I didn't find it yet.
The real maytery is what causes it to happen. With a used bike, you have no idea if the previous owner had brain fade and rode around all day with the choke on the 1st notch. (I'm guessing that something like that may be the thing that does it in...)
You can host your Photos at:
Then link them to this forum.
I have also changed my choke plate. I got a Precision Concepts Billet choke plate. I change it as soon as I found out they break.
But I think its more common on the XR600's.
The real maytery (mystery) is what causes it to happen.
A good explanation of how it comes loose can be found here.
I would not recommend trying the temp repair shown, just replace the stocker with the aftermarket choke plate (I went with XR's Only).
And use the newest #2 phillips screwdriver you have (or a fresh apex tip) to get the stock screws loose... :cry:
Some of the guys were making their own out of old 2smoke reeds, the carbon/graphite ones, so if they broke, they were "digestable". I've never owned a 2, but am looking around for somebody with some old reeds to try. :cry:
Digestable :cry: We use air filters to keep ultra fine dust out because it damages engines, but you want to run the risk of lunching some carbon/graphite!!! :cry:
Well I was all set to upload the pics to bikepics, but I decided not too when I read this:
"Due to increasing traffic I am now deleting all non bike photos that are uploaded. If you upload a photo that does not have a bike in it then it will be deleted within 24 hrs. This also includes forum avatars and other pictures that are uploaded solely for forum posts to link to."
I cropped them down to 280k total, so it wouldn't be much traffic but I rather not annoy the guy.
I got a new plate from XRs only and its way nicer than that crappy pic on their website. Oh well, its a good excuse to rebuild the top end. While I'm waiting on gaskets and such to come in, I'm rebuilding a semi-basket case xr500 and I noticed the carb is almost exactly the same design as the 400 except it has an accelerater pump which is made into the bowl, so it seems like it would be easy to make it fit the 400's carb, all you need is to drill a hole into the throat and put a nozzle, but back on topic, it has a solid choke plate. If the 500 didn't need a backfire flap, why would the 400?
Not digestable on purpose, but if something does go through the engine, I would rather it be a carbon fiber than alum. or steel. The carbon fiber reeds were designed to go through a 2 stroke with less damage.
Nice pics fishbone, after reading most of the post on this topic I took it as the Flap was the problem, now from the pics I see the bottom of the plate is also a weak point. How was it replacing the plate, did you have any issues removing the mounting screws? I've been reading that they are crushed on the one side so they dont fall out.
I had no problems at all. They came right out. Luckily my son was smart enough to not pull start the bike when it wouldn't start. I guess the damage could have been worse if he had.
Mine looked just like that but the piece that came off was still in one piece and far less chewed up looking. I say was in one piece because when I handed it to my dad for him to examine, he broke it to see how strong it was. The flap on mine also has marks and is bent from beating on the screws.
I took my brothers '02 apart to replace the plate and its different from the '99. It is made out of a solid stamped plate instead of that weak cast junk, but it still has the flap.
I didn't have any trouble getting the old screws out, but I messed up that spring on the end of the shaft and it took forever to get it to not lock up, don't think I did anything different but it just happened to work that last time I put it together.
  • Similar Content
    • By Kev_XR
      If you own an XR250, many of these tips will apply, however, the carburator jet sizes will be different.
      It really helps others answer your questions.
      I will fix them as time allows.
      Until then the Search Feature and enter "kevin's xr400 mods".
      The results will bring up most of the links.
      Here are some frequently asked questions I have answered before.
      Which XR should I buy?
      The longer the straights, the taller the hills, the deeper the sand; the bigger XR you want. The tighter the trail, the smaller hills, firmer terrain; the smaller XR you want.
      The XR400 has a great motor that will pull you almost anywhere. You can be sloppy on a hill climb on an XR400, where you have to keep the 250 singing. The XR400 weight is most noticable when you drop it or try to stop it going down a long downhill. (Moooomentum!)
      The XR250 feels like a mtn bike compared to the XR400. My friend rode his XR250 for years before decided he needed more power. Even then you can add a 300 kit and get good power.
      If you were heading to ride fireroads in Baja, I'd tell you to get the 600/650.
      To the tight woods, get the 250.
      A lot of both, the 400.
      Dual-sporting? Go bigger for more freeway, but don't show up at the trailhead with too big of a bike.
      All of the XR's are great. Pick the one that fits your needs.
      Gordon's Mods for XR400 (Uncorking the bottle up performance)
      XR400 History
      The changes to the XR400 have been listed here several times. This list appears to be complete.
      In addition, HairyScary discusses how to tell if a part has been updated by the part number. Good tip!
      XR400 history
      Getting the Spark plug out
      It seems the MotionPro spark plug socket does not work on the XR400R, but works on the XR250R.
      There is an OEM tool kit being sold on eBay that seems to work.
      717448 XR400 oil change
      Here is a way to make changing the oil much cleaner.
      This tips is really handy if you have a skid plate.
      XR400 oil change
      XR400 FAQ by Paul Gortmaker
      Paul usually has very good info.
      Small bolts
      BE CAREFULL with the bolts on the oil filter cover!
      An oil covered bolt will not torque at the same rate as a dry bolt.
      The friction doesn't build up, the force simply builds until the threads strip.
      This is the reason many people strip out these bolts.
      Here is an execllent website on bolts, oil, and misc values.
      Did you ever wonder why a 8mm box wrench is half as long as a 18mm box wrench?
      It is shorter as most 8mm bolts cannot take very much torque.
      I highly recommend getting getting an 1/4" socket set.
      I bought the Craftsman set at Orchard (owned by Sears), which tends to sell them for less.
      What is the Snorkle?
      This place has a description and pic, it's easy after you pull the seat. I siliconed a piece of coarse screen (fiberglass) over mine to keep bugs and stuff out. - NORTEXT
      717439 XR400/250 Pre-Filter
      After pulling the snorkle, there is a big hole on the top of your XR400. My friend showed me this prefilter trick.
      767409 XR400 Engine Bog, Pilot jet, and the Fuel Screw
      On XR400's twisting the throttle from fully closed to wide open will cause the engine to "bog" or in some cases die.
      831305 Valve adjustment (Am I retarded...)
      Inspect and adjust valve clearance while the engine is cold (35C, 95F).
      Valve adjustment
      389095 bigger jets (Lists stock jet sizes.)
      96-97 XR400's were jetted assuming you would remove the intake and exhaust snorkel.
      98 and later XR's were jetted assuming you would leave them in.
      bigger jets
      739907 Cheap Tool for Setting the Fork Oil Height
      There are some really nice tools out there for doing this job.
      This tool costs $4.49 at Kragen.
      Cheap Tool
      392932 high altitude jetting
      There are two big factors for jetting, elevation and temperature.
      Allen screws for the XR400 carb
      This lists the screws you need to convert the XR400 carb to use allen screws.
      Allen screws
      Screws for the brake and clutch after removing the stock handguards
      TBD - There is a post with the shorter screw part numbers for after the stock handguards are removed. Use search.
      Very quick engine hop up
      This is a very minimal change that should take less than an hour.
      Most of that time is removing the float bowl (3 screws).
      If you decide to do the full "Gordon's Mods" later, you will need to replace the jets again.
      o Pull the intake snorkle.
      o Add a UniFilter.
      o Pilot jet to 55, main jet to 155. (Assuming sea level and moderate air temps.)
      Source: Motocross Action magazine.
      Quick engine hop up
      Gordon's mods
      Baja Designs Baja Baffle with 96' spark arrestor.
      Pull the intake snorkle, UniFilter, 60 pilot jet, 162 main jet.
      (Depending on altitude and temp.)
      What to add to a new XR400 or XR250?
      Acerbis wrap around style handguards (saves levers and bars as they don't dig in)
      Baja Designs skid plate (Made by Utah Sports Cycle)
      Acerbis fork/disc protector
      Grease headset and rear linkage
      Spend you money on the suspension, not a pipe!
      First get some stiffer fork springs (96-97, 98-99 years)
      Fork revalve (cost: 2 qts of oil & time)
      Shock revalve (cost: oil, nitrogen, shim stack, friend who knows shocks)
      Jetting for Altitude (XR400)
      Assuming at sea level and 68 degrees, you would use a 60 pilot and 162 main.
      At 5000 feet and 68 degrees.
      Jettting correction:
      Main 0.96 * 162 = 155 -> 155 main
      Pilot 0.92 * 60 = 50.6 -> 55 pilot
      Due to your elevation, you have less air and less fuel.
      Your bike will not behave the same as a bike at sealevel.
      First, check the fuel screw. If it does not affect the idle speed, you have the wrong one.
      kevin's xr400 mods
    • By Child
      Can we make a sticky thread of pictures? I've done search for pics but I want to see all sorts of bikes just for ideas on stuff without having to go through tons of threads. Not trying to sound whiny or anything, but I think it would be nice to do what they do in the CRF250X forums with a sticky thread of just pics, no comments or anything. Think we can get one of those rolling here?
    • By kawamatt2
      Ok guys, add one more to the list of riders attempting the USD fork swap to an XR frame. Quite a bit of research here on TT and ebay hunting brought me a pretty good deal on a set of forks, triples, and stem from a 00' CR 250.
      There are a few different options for adapting CR style forks to an XR. Bushings for upper and lower CR triples can be made to allow use of the stock XR stem. Specialty bearings can also be purchased to allow use of the stock CR stem in the XR neck. And finally what seems to be the most common; modification of the stock CR stem to allow use of XR sized bearings.
      I obviously chose to pursue the third option for a few reasons, the most prominent of which is serviceability. I wanted to keep as many wear items at possible as stock parts. This has two advantages; availability and price of replacement parts. $45 dollar a pop "specialty" thin section tapered bearings don't sound too appealing especially when being used on a 12 year old dirtbike.
      So now we can get to the meat of the issue; modification of the CR stem. I should begin by saying that i am NOT a draftsman. I've taken a few classes on engineering measurements but am far from an expert and probably only mildly proficient reverse modeling components. With that said, the first order of business was comparing an XR stem and bearings to a CR stem and bearings. Shown below.
      A little closer look at the XR setup.
      And the CR setup.
      Now to get out the calipers and model up the stock CR piece. I used a cheaper set of calipers and suspect their tolerance is +/- .01mm. Good enough for gov'ment work though! All dimensions in millimeters.
      Now to modify the CR stem to work with the XR bearings while remaining compatible with CR triple trees. There are a few things to say about why i did some things the way i did but most of the thoughts are included in the notes section of the drawing.
      With a resized stem we run into the problem of mounting the top triple clamp. The hole is too large for the stem. An insert bushing must be made to resize the hole in the clamp.
      Finally what the stem and bushing look like together.
      Last one. The difference in how the top triple clamp is located on the stem. The CR is equipped with a chamfer that provides a stop for the tree while the XR's triple appears to be limited only by the threads for the castle nut.
      So... would like to hear your opinions on the execution of the stem modification and bushing. I think having these drawings will make it simpler to have the modifications performed as opposed to asking the machinist to completely reverse engineer the part him/herself.
      And a final query: Anyone know the thread callout for the two threaded portion of a stock XR steering stem? My drawings show the outside diameter of the threaded portions and i have a cheap plastic pitch gauge that tells me a pitch of 1.0 but i am looking for something more concrete than what i have.
      Thanks for your thoughts and opinions.
    • By ATJ_Number_1
      I'm on strike 2 here but thankfully this isn't baseball.
      The reasoning and my history. If you haven't figured it out yet I've done a crap load of work on these motors over the last 7 years but they have had 4 wheels around them. In the EX world there are a lot of carburetor options and although many are great there's a cheap alternative that runs 95% as hard as the high dollar options, some even liking it better then aftermarket. When I joined up here in the 2 wheel club I was shocked that the only accepted option was $400 for a 36mm Mikuni Pumper that isn't any bigger then stock! That cheap alternative for the EX is an 04-05 trx450r carb. It's 42mm round slide Kiehin piston-valve with accelerator pump and a mildly modded 400 loves it with a surprisingly strong bottom end yet. Yes I said 42mm!
      So as I build my XR4 I already know that I'd be shooting myself in the foot if I settled on a 36mm carb because I like bigger bores and cams and this motor likes bigger carbs. Makes sense, it is 400cc. Don't get me wrong though, the Mikuni is a real nice pumper for a stock bike and would seem fine on a well modded machine too but this 4 stroke is like every other one in the world in regards to when you go big inside, you want to go bigger outside or you're missing out.
      Whether the info is appreciated or scoffed at I'll post up my findings one by one as I try to find viable alternatives. When I say viable I mean still being able to use the stock environment and not needing a ton of work. I'm sure collectively this is not a new idea to search for such a beast but I enjoy a good project and I like cheap alternatives when they produce results.
      Currently the "test bike" is a 2000 Xr400r, snorkel removed, Uni filter, stock engine, stock headpipe and a 4" supertrapp slip-on with 11 discs.
    • By XL100allnightlong
      Just wondering if there is any tricks to polishing the stock headers on an 02 xr 400 to bring back the original copper color? If not ceramic coating them sounds like an option?
