Help - stuck in 1st gear!
Been riding today and had a slight "off" on a muddy trail &
subsequently got stuck in 1st gear & unable to select neutral or
anything else. I didnt hit any rocks etc as far as I know so it a bit of a mystery as to whats caused the problem.
Any suggestions or thoughts anyone?
Cheers
Chris
Lets try the easy stuff first
Undo the gear leavers clamp bolt and slide it off the shaft
Put it back on the shaft one spline up from level with the foot peg or wherever you wish
& do up the clamp bolt
Make shore that it isn’t running into anything and see if it works
You have probably just bent it a little and its hitting the bottom of the case
Let us now the outcome
