05 KTM''s
I was looking at the 05 KTM's and noticed on the EXC and MXC models that they have a new swingarm. I was told that the swingarm is one piece and slightly longer, I also noticed that on these models that the swingarm is no longer polished as the years before and is a flat gray color...
Which I really dont like...I like the shiny chrome better.
I was wondering if anyone has any information on this new swingarm set up on the EXC and MXC models...any information good or bad would be appericated.
And does anyone know if these new swingarms can be polished up like the other ones.
Take care & be safe
Tccra X18
Toro A417-A401
The swingarm is "a stronger, one-piece, cast unit". You should be able to polish it if that's what you want, but why would you? Just for the look?
Who cares what it looks like if it works better? :cry:
Storm Trooper is right. Its all cast. There are no welds on the whole thing. I admit that I like the polished look too, but the look of that new swingarm has really been growing on me lately.
I have to admit though it looks as if it were a leftover from something else. There is a real big space up in front of the shock and plastic covers over some round cavities that look like the swingarm was designed for use of a linkage type rear shock. :cry:
Thanks for the replys...I do like the polish over the flat gray. To me it looks better and it also cleans easier and does not spot like I heard??? not really sure about the spotting or staining, its just want I was told.
Thanks again
The round holes are from the casting process, not where a linkage should bolt in. The big space up front is there on all KTM's even pre 05. If it was a solid chunk of aluminum up there, everyone would complain about the weight. The swingarm is a new, KTM exclusive, design.
Ok, well now I feel a little better. Somebody somewhere said they were leftover Husaberg swingarms. :cry: Whatever it is it works great.
The 05 EXC swingarm is specifically designed to suit the 18 inch wheel. Its design allows for better resistance to flex generated by an 18 inch wheel (Don't ask me what that is). Team KTM manager told me that it made by the same company that makes the Husaberg arm and thats why it looks similar. I think they look great in the flesh. Remember KTM owns Husaberg.
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
