selecting neutral
I've got a KTM 620 LC4, it has real problems selecting the neutral gear, it's OK with the engine stopped or when it's first started.
I've checked the cluch and it looks OK, anyone got any ideas ??
I have a 1996 620 exc that is hard to get into neutral when it is running but it goes into neutral when it is off just fine. Just resantly had a problem with the cluch not wanting to release all the way. took the clutch apart to check clutch is fine but the inner basket has a problem. The inner basket has a lot of little wear indents on it. Did you check out the clutch baskets or just the frictions?
Its supposed to do so. Just need to get used to it.
