KTM Seats???
I got a chance to ride a friend's new KTM 450 EXC last Saturday, and I have to say that even in the Colorado mountains it is the most incredible bike I have ever ridden :cry: I would love to pick one of these up some day, but I have to ask, with such a great machine, why is KTM so incapable of making a decent seat? It is like sitting on a brick! Is there an aftermarket supplier for seats for this machine? I just can't see being able to ride for long distances on that seat the way I can on my XR600. Certainly there has to be a softer trail riding seat out there somewhere???
Yes there are a few; Enduro Engineering;Guts Racing; and a couple of other I cant remember. Just do a search here or KTMTALK.com
It must have been an '04 because the '05 seat is much more plesant that KTM of the past. At least on the 450exc I rode anyway.
The seat on my 2005 525 MXC is every bit as plush as the seat on my 2003 CRF 450. It must have been an '04. :cry:
MXC seats and EXC seats are different.
To my knowledge there is no difference between 04 and 05 seats.
(Anyway... simply ride enough to train your butt :cry: )
I have the EXC seat and tank combo on my MXC.
The KTM seats in the past were very hard. There is no way I could ride one without getting a major case of monkey butt.
Compared to an XR600 just about anything will feel hard. That big fat seat on
the XR was made for sitting for long periods of time. Not the case with a competition/race bike.
I rode a bubbies 450 and he had a GUTS seat on it. It was so nice I didn't stand up the whole time I was riding his bike.
Ditto!! Before I went to a Guts seat I could last maybe a few hours. After the new seat I did my first 100 miler in Mammoth...GUTS is the way to go!!
Guts Racing Home Page
The soft seat is what I have on my 04 200 exc and my 04 450exc
they are cheap (if you get a deal) and all you does is bolt the sucker on!
  • Similar Content
    • By Ponch
      I have a 2007 450 EXC that I recently installed a new clutch slave cylinder on. Per the 2007 KTM service manual it clearly states that the clutch needs to be filled with hydraulic oil, which I did (magura blood). That was yesterday. I went out to double check the level today and when I removed the cover, the rubber seal was all contorted and out of shape. I then looked at the cover and it's a Brembo clutch and says "DOT 4 brake fluid only".
      I flushed the line and the master cylinder about 7 times with DOT 4 brake fluid and there was no sign of the magura blood left in the system. My question is: other than the rubber boot on the master cylinder, what damage might have been done by putting in the hydraulic oil? It was in for about 24 hours.
      Thanks in advance for any advice!
    • By pumpernickelBrad
      Hi Folks!
      Sorry if there are a bunch of threads already but I used the site's search function and didn't find anything so far...
      I just found a decent deal on a '14 350 EXC-F with 11k km (unknown hours). Has a few goodies including skid plate, hand guards and it's for sale for about $2k CAD less than a '16 with 6k km on it.
      The bike is in showroom condition (appearance) with no indication it has been offroad at all.
      What would be the gotchas that would make this deal realistic? I'm coming from a WR250R where the engine lasts forever, is 11k street kms high for these bikes?
      Are there any big defects in the '14s that I haven't dug up yet?
      With no service records what things should be done, checked, etc?
    • By Brannnt
      I purchased an '06 525 EXC some time ago, and recently pulled the motor out of the frame to address some other issues. When I removed the clutch slave cylinder, I noticed an issue the previous owner neglected to tell me about during the purchase.
      It appears that at some point, the chain broke and damaged the engine case near the clutch slave cylinder (see pics, please). I have noticed that the clutch does not fully disengage (bike lurches a bit going into gear, neutral is hard to find... its worse when engine is cold) ... I did not notice any leaks around this area (mineral oil or engine oil) before or during disassembly.
      The previous owner (or someone) repaired it with some sort of epoxy.
      Without doing my due diligence (checking clutch fluid level, bleeding) I hesitate to state that this is the cause of my clutch disengagement issue ... but pardon my ignorance here and help me out: How bad is this?  Am I looking at replacing my engine case here or is the previous owner's jerry rig good enough?
    • By Black Sox
      Just bought a new 2017 350 excf ,will be doing 98% off road ,ordered skid plate bark busters ,
      my ? Is what's the best easiest way to eliminate rear fender light assembly.I still would like to have a break light.
      xcf fender will fit so dealer says,under $50.00 👍But xcf brake light $125.00 .👎What's the best economical way of doing this?
    • By JNV
      Hi friends from Spain.
      Mi new KTM
