Whose "S" model is at Corona Motorsports?
Took in my '01 E to have it re-jetted (yes I could do it, and yes Im lazy! :cry:) and noticed someone's "S" model in there having all the latest tricks done. The mechanic broke out the list of mod's for this guy and I noticed they they were all printed out from this forum. The bike was looking good! New Pro Tapers, a new steering dampner (SP?), new tires, air box mod, tank, pipe, and so on. Should be really nice.
So far I've done the full Yosh system, pulled the snorkel, installed a Twin Air, and bar risers are on the way. This alone has made my "E" model quite quick and fun. Well, the CA license plate makes it fun too! Mods are addicting! :cry:
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
