How much output does this "S" model's 3phase generator put out?
My question is a simple one, from a simple man. How much power can my generator put out? Watts,AMPs, Volts, etc. :cry:
Advertised as 12 volts DC, 200 watts. That is about 16 amps. However I would not count on that as continuous output. Automotive (and I assume motorcycle) alternators are way over rated. I would guess more like 10 to 12 amps continuous. The alternator is sized to the normal load with a little reserve. People have been successful adding 50 watts of load. I would think that is near the maximum I would want to add to the system. Why do you ask?
I just got my drz400s service manuel and it says 200 watt peak @5000 :cry:
  • Similar Content
    • By Bgringo
    • By Markl5557
    • By RockyMtnMark
      Good Morning,
    • By Zach440
      -doubletake mirrors
      -thumpertalk case savers
      -Shorai lithium battery
      -led headlight
    • By tplayer100
      Currently have a 2000 drz400s work stock suspension. From my understanding this is the worst suspension the drz ever came with without even rebound damping adjustment. Therefore I'm looking for a upgrade. I'm seeing three approaches to take. First being a newer year s model suspension with dampening adjustment. A SM model USD forks and triple tree or some USD forks and triple tree from a rmz. So if you were going to upgrade what direction would you go. I currently ride off-road mostly but I do have some 17s for on road with as well so have to keep that in mind. Thanks
