aluminum sprocket lasts all year?
I have been consistantly riding 2-3 times a week since march and racing once a month in our NM desert racing series. I replaced the crap stock chain that was on my yz in june but haven't done anything else to the sprockets...
I realized last night that the bike has an aluminum rear sprocket! I have heard so much stuff about them being crap and only lasting a few rides?! I will get a whole season out of this one.
if you ride in dry weather, they can hold up pretty well. i got about 3000 miles out of the stock sprocket on my 300, but it was pretty well toasted when i replaced it. it also makes a big difference riding with a good o-ring chain, since it doesn't wear as fast, and therefore doesn't chew through the sprockets as fast.
mw
Yeah, my bro has the same bike and i just put a new sprocket on his, he sees mud all the time in NJ and his sprocket was trashed, teeth missing and everything. He probably rides 2 times a month. We both have 04s.
Mud kills your drivetrain.
I have been using a regular primary drive chain. I also use 'gunk' brand industrial chain lube that you get at home depot. it is 2$ a can.
With the bike you have, it should go through a aluminum in 6 rides or so!
Sure its aluminum? 😢
The type of bike has absolutely nothing to do with how long sprockets last.
Long life of sprockets depends on proper alignement, chain tension, and not running a chain that has grown in pitch past specs.
As a matter of fact, if you never run a chain that is more than 1-2% elongated, (and you keep the alignment and chain tension proper) your aluminum sprockets will last as long as any other sprocket will...almost indefinately.
You should always replace the sprockets when you replace the chain. If you do, you will get maximum life from both. A hooked sprocket will ruin a new chain fairly quickly.
I get about 1000 miles out of my aluminum sprocket on my big bore thumper, FE501e. For dirt / desert use, that is pretty good.
