brass shavings in oil at oil change ok or BAD
hello all my bike has been going well i changed the oil the other day i recently purchased it used from a guy its an 03 drze i changed the oil when i got it no brass shavings then i took a 85 mile runn in mountains got back and changed oil i was running castrol motorcycle 20/50 wtreg oil and it had brass shavings in oil the magnetic drain plug had no metal is this normal or should i dump this bike and get another drze thanks for you input jt
change the oil and filter,along with cleaning the frame screen.use a good motorcyle oil and try it again.
i wouldnt be suprised if the oil had never been changed.
Where's the frame screen? :cry:
Larger hole, top center of this pic at the bottom of the front frame member.
